rear axle fluid change
Old Jun 26, 2003 | 08:19 PM
stonecoldz's Avatar
Question rear axle fluid change
hey,
i wanna do a rear axle fluid change. i wanted to know how many bottles of axle lubricant part#12345977 and how many limited slip lubricant additive part # 105238 do i need?
anybody have the part # for the gasket?
thanks
Old Jun 26, 2003 | 08:54 PM
Bud M's Avatar
It takes about 1 1/2 quarts of gear lube and 1 bottle of Limited Slip additive.
Old Jun 26, 2003 | 09:01 PM
revtime's Avatar
3.5 pints.
I am so dumb I had to look up how many quarts that was. I should have paid attention in school.
Bud is correct.
I just did it today, why does the stuff smell so bad?
Old Jun 26, 2003 | 09:08 PM
Z-Attitude's Avatar
You can get a gasket at any parts store. Check this site for instructions.
http://www.bfranker.badz28.com/fbody/lubeoil.htm
The rest of that site has everything you need for your F-body. Later>>>>>>
Old Jun 26, 2003 | 09:54 PM
Prorac1's Avatar
But if you use synthetic lube you dont need posi addative, and it might prolong the life of your factory posi unit, just food for thought, hope it helps, prorac1
Old Jun 26, 2003 | 11:13 PM
Bud M's Avatar
I used LS additive with synthetic gear lube. No problems.
PCLZ28
Dec 24, 2015 05:19 PM
4586
Jan 3, 2015 07:22 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
rockync7
Jan 1, 2015 05:10 AM
FredM
Dec 18, 2014 01:40 PM
