Rean main question
Old Jul 21, 2004 | 11:19 PM
Hawk350's Avatar
Rean main question
I am seeing oil spots on the ground, it's not tranny fluid as I first thought. I searched the forum here and I checked the manifold gasket in the back of the engine and it's not wet. Is the only thing that can be leaking is the ream main seal? I dont think that it could be anything else at this point...any suggestions?
Old Jul 21, 2004 | 11:21 PM
944v8inDFW's Avatar
Re: Rean main question
Valve cover gaskets??? Is the leak in the center of the car or off to one side? Maybe oil pressure sending unit??? Is the oil filter tight???
You can get some oil dye to help you pinpoint where it is leaking or you can clean everything real well, drive it, then observe.
Old Aug 5, 2004 | 05:20 PM
jer4251's Avatar
I found that my rear main seal is leaking also, it's comming out around the tranny gasket, almost looks like the gasket came out a little, i'm not an expert but i need to fix it some how. if i get it all clean and put some rtv sealent around it will it hold? has anyone else fixed this problem without dropping the oil pan?
RUENUF
Mar 13, 2016 03:39 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
stavos
Aug 27, 2002 12:24 PM
Camaro90RS
Jul 23, 2002 07:57 AM
