Rean main question
Rean main question
I am seeing oil spots on the ground, it's not tranny fluid as I first thought. I searched the forum here and I checked the manifold gasket in the back of the engine and it's not wet. Is the only thing that can be leaking is the ream main seal? I dont think that it could be anything else at this point...any suggestions?
Re: Rean main question
I found that my rear main seal is leaking also, it's comming out around the tranny gasket, almost looks like the gasket came out a little, i'm not an expert but i need to fix it some how. if i get it all clean and put some rtv sealent around it will it hold? has anyone else fixed this problem without dropping the oil pan?
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Camaro90RS
Jul 23, 2002 07:57 AM
