Rassin Frassin Headers bolts!!!!! ANYONE in
Old Mar 3, 2004 | 01:00 AM
S.J.S.'s Avatar
They're driving me nutz!!!. Every other week I have to tighten them down. They are only the rears. #7 and 8. Why only the rears and how do I get rid of the problem.
Old Mar 3, 2004 | 01:14 AM
96ta(nick)'s Avatar
stage 8 locking header bolts
Old Mar 3, 2004 | 05:21 AM
magius231's Avatar
you don't need stage 8 locking bolts, you need to be religious about tightening them in the beginning. When I first installed mine I tightened them after letting the car idle for a bit, again after a 10 minute drive, again after a 2 hour drive, and then every week. Did that for about a month and haven't had a header bolt loosen on me since. If its coming loose every 2 weeks, shorten your schedule and tighten once a week until they don't loosen anymore.
Its a lot better than having to dink with those stupid little clips on the stage 8's...
Old Mar 3, 2004 | 06:30 AM
Brent94Z's Avatar
Super Moderator
I've got the stage 8's but you can't use the clips on most of the bolts... they are too close to the header. Still easier though because you can use an allen wrench.
Old Mar 3, 2004 | 07:03 AM
S.J.S.'s Avatar
so just tighten them more frequently even when they're not loose at all or barely loose? I'll try that. Any other suggestions?
Old Mar 3, 2004 | 08:26 AM
rocmemphis's Avatar
Breslin header bolts...I cant say enough good things about them. Stage 8 bolts are nothing compared to the Breslins.
Old Mar 3, 2004 | 07:28 PM
magius231's Avatar
just keep tightening them loose or not unti lthey all stop being loose...then leave it for longer and see if they loosen. I don't have to look at mine at all anymore.
I used ARP 3/4 bolts, everyone said use 1" though..no problems at all.
Old Mar 3, 2004 | 07:52 PM
got_hp?'s Avatar
stage8 suck..........they strip WAY too easy
Old Mar 3, 2004 | 11:22 PM
S.J.S.'s Avatar
anyone else????
Old Mar 4, 2004 | 12:42 AM
Johnnynsac's Avatar
If the Stage 8's don't fit what you want to do is file them down a bit then slide them in.
Tighting them up every week? no way, now thats a pain when your in a hurry.
Are you guys sure Breslin bolts work?
Old Mar 4, 2004 | 01:26 AM
Steve in Seattle's Avatar
In theory they should work as planned... however the design just doesn't make me comfortable using them in aluminum heads. The thead BOTTOMS squeeze out into the aluminum, and you pray that the little allen-head doesn't strip (which they always seem to for me ).
I'm going with ARP 12-point bolts... 1" long. Considered studs, but the area in there REALLY is tight... I dunno if it's worth the extra effort/cost.
Old Mar 4, 2004 | 01:32 AM
carlos64030's Avatar
www.go-breslin.com No other header bolt can hold a candle to these....I love them!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
