random/multiple misfire......PLZ HELP!
Old Jun 27, 2007 | 10:23 PM
green96ta's Avatar
well i just put some 3.73s in my car. now everytime i drive for an extended period on a parkway at like 75 or so im tachin like 2300-2700. my check engine light comes on and and its a random misfire code. i was thinking that it could be one of two things...my knock module since my exhaust is loud and road noise. or i think it could be my opti...please help and any input is greatly appreciated....here are my mods...
Mods-Madz28.com tune, true duals w/ dynomax race bullets, CATS delete, A.I.R. delete, Smooth intake elbow, MSD wires and coil, K&N cold air, Spectre ram air, 3.73s, Eibach Sportline springs, Energy Supension transmission mount and Torque arm bushing.
Old Jun 27, 2007 | 11:49 PM
Angelis83LT's Avatar
Probably the opti.. sounds like it.
Old Jun 28, 2007 | 12:59 AM
green96ta's Avatar
bump
could use a couple more opinions before i go tearing into that opti, esp since thats one helluva job and costly too...
Old Jun 28, 2007 | 01:03 AM
speed_demon24's Avatar
It could be plugs,wires,coil,icm,02's, or the opti. Take your pick.
Old Jun 28, 2007 | 09:24 AM
green96ta's Avatar
hmm
i have new plugs and wires, not even 5,000 miles on them...if it was one of the first two o2 sensors wouldnt it throw that code? i had the back two programmed out.
Old Jun 28, 2007 | 09:37 AM
GaJoe's Avatar
check to be sure none of the plug wires are grounding on the exhaust...sounds like that is a possibility since it's happening at running temp....as another option, you can take off the icm and have it tested before you went tearing into the opti...just a maybe!
Old Jun 28, 2007 | 11:09 AM
moparman's Avatar
Yes, start by rechecking plugs and wires.
Old Jun 28, 2007 | 11:48 AM
green96ta's Avatar
all good
well i checked all the plugs and wires, ill check the icm when i go to work tonight....what else could it be, its only when the car stays at a mid range rmp for a sustained amount of time
Old Jun 28, 2007 | 01:15 PM
96LT1TX's Avatar
sorry but, it really sounds like plugs/wires to me. Could be coil, opti also, but to me it sounds like plugs/wires. Check for arcing (turn lights out at night and look for light coming from under hood), check for wires on headers, check your plugs if this checks out.
I bet you have a burnt plug wire somewhere.
Old Jun 28, 2007 | 10:13 PM
green96ta's Avatar
it only does it
it only does it after driving at a sustained 2400-2800 for about 30-40 min...DOES NOT COME ON BEFORE>>>>>>>ONLY AFTER DRIVING 30-40 MIN
Old Jun 29, 2007 | 08:36 AM
Eck's Avatar
Eck
Right, we understand. Still could be plugs/wires. Mine did this a while back and it turned out to be wires.
The time before it was the opti.
Old Jun 30, 2007 | 11:12 AM
pat35's Avatar
sent pm. can help you dinose if you have a scaner.or tell you a dereckin to go. sary for spelling have deslexia . bin a teck for 25 years.
Performabuilt
30
May 14, 2009 05:25 PM
green.Z
Mar 29, 2009 07:57 AM
blwnlt4
Mar 18, 2009 11:57 PM
LSWHO
Jan 22, 2009 11:08 AM
LSWHO
Sep 27, 2008 11:17 PM
