Rag Joint, Question?
Old Dec 12, 2003 | 09:01 AM
  #16
Stoopalini's Avatar
It's not that difficult to replace. Two 11mm bolts will allow you to remove the steering shaft from the car. Then you have to get the rivits out. I put the shaft in my bench vice and used a 4" grinder with a grinding disc to grind down the rivit heads. Then a puch & hammer took the rivits right out.
I'd say the whole job took a little less than an hour to do with the 4" grinder. If you have to use a drill, I would think it will take quite a bit longer.
Again, after replacing the factory joint with the unbalenced engineering eliminator, I do not notice any increased vibrations at all. The steering wheel does not vibrate any more than it use to regardless if I'm going down the highway, going over speed bumbs, pot holes, gravel road, etc ....
As far as the safety bit, the chances of a front end collision pushing the steering column into the cockpit are much greater than it pushing the whole motor into the cockpit. Have you ever seen a car after a front end collision? Usually it's the dash/steering column/instrument panel that ends up in the passenger's lap; not the motor.
Thomas.
Old Dec 12, 2003 | 11:23 AM
  #17
Heatmaker's Avatar
Advanced Member
The Steering Link is hard as hell to get out...you have to bang on it and slide it around...It's impossible if you have headers...Putting it on is even worse!
Old Dec 12, 2003 | 01:07 PM
  #18
Stoopalini's Avatar
Hmm, my car has 91k miles on the odometer and it wasn't at all difficult to remove the steering link/shaft. If you had difficulties removing yours, I'd have to say each car is unique, and the ease of removing it will vary.
The reason for the difference in our case is most likely Texas weather being nicer to the component than the east coast weather.
After removing the two 11mm bolts, I had the shaft out in just a few seconds ...... no B.S.!
Thomas.
Old Dec 12, 2003 | 09:38 PM
  #19
Unique07's Avatar
Originally posted by aram
I think a lot of cars have a direct connection (no rag joint) and are perfectly fine.
A lot...? I'll settle for you naming only two...without going back 40yrs, I can't think of any...
Old Dec 12, 2003 | 09:47 PM
  #20
Spinner's Avatar
I got my shaft out in 2 minutes too.
Old Dec 12, 2003 | 09:58 PM
  #21
Red96Lt1's Avatar
What it the P/N for a rag joint.
Old Dec 13, 2003 | 03:38 AM
  #22
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
LS1 cars don't have a rag joint ...
Old Dec 13, 2003 | 03:57 AM
  #23
93formula's Avatar
really? whats there part number may work for our cars
Old Dec 13, 2003 | 07:14 AM
  #24
They don't .... Unless you like the steering wheel to sit 90* away from being centered. But other than that, it's a direct drop in.. Same length and everything.
Old Dec 13, 2003 | 03:03 PM
  #25
Red96Lt1's Avatar
Anyone with a P/N for a rag joint for an LT1? Thanks!
Old Dec 14, 2003 | 12:01 AM
  #26
Heatmaker's Avatar
Advanced Member
I'm with Red...what's the PArt Number?
Old Dec 15, 2003 | 07:38 AM
  #27
Red96Lt1's Avatar
P/N anyone?
Old Dec 15, 2003 | 08:30 AM
  #28
Mr.Whitey's Avatar
http://www.unbalancedengineering.com/Camaro/Rag_Joint/
Victor Lamb
Aug 26, 2017 02:52 PM
VF-124
Mar 16, 2015 08:14 PM
blac94Z
15
Mar 2, 2015 12:00 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
dreamer1q
Sep 8, 2002 08:48 AM
