Raditor stop leak?
Old Jun 29, 2003 | 11:07 PM
95BlackTA's Avatar
Raditor stop leak?
Ok I just found a spot where a hose is leaking out a lil coolant from my radiator. So i went to discount, but they cant even ORDER the hose I need(Bypass hose)...im like wtf....okkkkkkkk
Anways I havent called Napa yet..but my question is, would it be easier to try some raditor leak stopper..or does that stuff not really work? Anyone have experience with it?
The leak seems to be coming from where its clamped on, so im guessing(hoping) a new hose would fix it if I need to do that.
Old Jun 29, 2003 | 11:13 PM
SloMofo's Avatar
I've used Bar's stop leak before and it worked, but it's only for minor leaks. Not sure if it's gonna do any good with a leak from a hose
Old Jun 30, 2003 | 12:06 AM
I would not use stop leak for a hose problem. It is best to try to avoid that stuff if you can.
Old Jun 30, 2003 | 12:10 AM
94GreenZ28's Avatar
I used it in my daily driver and it stopped the a decent sized leak. But I'm sur eit gums up the inside of your engine.
Old Jun 30, 2003 | 07:43 AM
scoobysnax83's Avatar
I'd find it real impressive if it could stop a leak from a hose.... You just gotta replace that thing.
BLK1997Z28
May 2, 2015 01:26 PM
Fatdog2
Apr 27, 2015 10:32 PM
Biggiebound
Apr 23, 2015 08:50 AM
BigWil
Mar 29, 2015 12:24 PM
alex5366
Feb 17, 2015 10:43 PM
