Radiator Fan tuning on even Cold Start ?
Old Jan 13, 2010 | 10:27 PM
Mir Hussain's Avatar
Does radidtor fan suppose to start on engine start. I mean I am talking about 28-30 F out side temp.
I notice little draft when I had hood open. It feels like it running on Speed1
Car is in Sig
Old Jan 14, 2010 | 05:28 AM
The fans will often come on at startup when there is an SES light.
Old Jan 14, 2010 | 09:34 AM
if there is no SES light, does fan come on ? when engine is cold as ice ( -20 -32 F)
Old Jan 14, 2010 | 09:40 AM
The fans should not run on startup. Not all codes turn on the SES light.
Old Jan 14, 2010 | 10:07 AM
Arrow
Hmm
I think I have a lead to follow here
Old Jan 15, 2010 | 09:12 AM
DirtyDaveW's Avatar
When my Knock sensor wire was grounded to the headers(Melt through), I had that occur.
Originally Posted by Mir Hussain
Hmm
Old Jan 15, 2010 | 10:24 AM
If the knock sensor wire is grounded, it should set a trouble code.
Old Jan 15, 2010 | 11:17 AM
DirtyDaveW's Avatar
Hehehe.. because of all my modifications, the SES light is on all the time.
Old Jan 15, 2010 | 12:05 PM
See fan coming on Often is one thing!
But Fan staying on with regardless of the temp is one thing
Now wire being grounded hmmm
I hate to do electrical wire trouble shooting
Old Jan 15, 2010 | 12:37 PM
DirtyDaveW's Avatar
If you can plug in a scan tool, see if any of your readings are out of normal ranges. That, at least, will allow you to focus on the most likely cause.
Best of luck to you!
Old Jan 15, 2010 | 05:14 PM
I have handy dandy Hypertech Scan tool. Which does not saying any thing out of ordinary
Old Jan 15, 2010 | 05:22 PM
Bersaglieri's Avatar
Which is why mine do I need to scan that thing.
-Dustin-
Old Jan 15, 2010 | 07:16 PM
teamstream's Avatar
I just got my car running, and my fan kicks on almost right away. when it does it pops 29 EAS Electrical fault...any idea what that means? i also have this suspicous wire on the pass side thats not hooked up and appears to have melted on the side where is hooks to a sensor. i enclosed a pic of the plug...any ideas?? i wasnt sure if this is all being cause my this wire unhooked? wire colors are green and black. http://s748.photobucket.com/albums/x...0115001859.jpg
Old Jan 15, 2010 | 10:33 PM
See My problem started
because I decided switch back to Standard Cam driven Water pump from my meizer Electric one.
Because I wanted to daily driven without a problem or concern. Not though I had a issue though, Silly me ?
After I have done all that, My radiator fans wont come on at all.
I took it local shop, he said from relay box where wires are going down and then comming back up and there where is a problem!
So he bypass that wires hookep directly to relay!
No I have not run the car for 1 1/2
When I done changing the water pump back I notice my Secondry Air pump is not comming on and it is giving me a code!
I didn't paid whole lot of attention at that time.
so they all could be releted too ?
Heck I might have hooked the Air inlet house back ward too Insted from Air Intake I might have hooked up to my headers!
Old Jan 16, 2010 | 10:15 AM
I already explained. When some codes set, the fans come on. You asked specifically about the fans coming on at COLD STARTUP. You did not ask about them staying on all the time. But just to clarify, since there seems to be a HUGE communications gap here - THE FANS WILL RUN ALL THE TIME WHEN SOME CODES ARE SET.
My comment about a grounded wire was not for you. I'm not sure why the post about the knock sensor was even added????
Are you reading anything that we are posting. I mentioned that the fans will run if there is an SES light. You told me no SES light. Then I mentioned that the fans will run if there are some codes. You ignored me. Now you are telling me you have a code for the AIR pump. That is a code, and it turns on the SES light. When it setS THE FANS RUN ALL THE TIME. That is why your fans are running all the time.
Now you are telling us someone altered the wiring to the fan relay. Don't you think info like that should have been posted up front?
And what does "No I have not run the car for 1 1/2" mean?
I really can't handle this... getting to damn old and cranky. Maybe someone else can help you.
