Radator leaking... :(
Old May 16, 2004 | 06:28 PM
NewbieWar's Avatar
it seems to be a crack in the radator casing.
well right where the fill cap is probably 2 inches lower there is a spewing stream of radator fluid. it seems when im going down hill and its hot so basically under pressure.
what can i do about it i dont have the money for a new radator or something and i know sealers usually clog the waterpump.
so what can i do?
Old May 16, 2004 | 07:03 PM
OBE1 95Z28's Avatar
I got a new radiator from radiators.com. Fit perfect and looks to be as good a quality as the original. $121 plus tax and shipping. It came quickly from a local warehouse. Has the fittings for both an A4 and a M6.
Old May 16, 2004 | 07:17 PM
My Red 93Z-28's Avatar
A local radiator shop put 2 new plastic casings on mine and flushed it out for about $45
Old May 16, 2004 | 08:03 PM
NewbieWar's Avatar
it seems like it is leaking out of the normal seam of the case, (plastic) so i wonder if i could get a radiator shop around here to do that too
Old May 16, 2004 | 08:16 PM
probably, double check the prices though, as its been awhile since I had it done.
But I know its cheaper than buying a new radiator.
Spllouder
Dec 6, 2007 01:42 PM
NewbieWar
Feb 1, 2004 07:25 AM
FLIPPINZ28
Dec 21, 2003 06:09 PM
dnz28
Aug 19, 2003 04:15 PM
