R & R Fuel Filter
Old Jun 3, 2004 | 03:34 PM
ASIM's Avatar
R & R Fuel Filter
Hey guys:
Going to re and re my fuel filter tonight. The guy at the dealership said I can release the fuel pressure by removing the cap and pulling the fuel pump fuse and turning the ignition to on. Is that good enough? I have heard about this schreader value but hear it is difficult to find.
Asim
Old Jun 3, 2004 | 03:45 PM
SWINGRRR's Avatar
Take the cap off and let the car sit for awhile before you start.
Old Jun 3, 2004 | 03:51 PM
If you have a healthy fuel system, it will hold pressure in the supply line for quite a while. Depressing the core of the Schrader valve (in addition to removing the gas cap) will eliminate any residual pressure. Hold a rag over it, and do it when the engine is cold. The Schrader valve is right behind the passenger side fuel rail. As usual, Shoebox has the "visual aids":
http://shbox.com/1/fp_reg.jpg
Old Jun 3, 2004 | 04:00 PM
ASIM's Avatar
Ok, Shreader valve. turns, pops off, etc?
Old Jun 3, 2004 | 04:04 PM
I also have a step by step procedure. The scrader valve has a little threaded cap on it (it's like a tire valve).
SWINGRRR's Avatar
Just push in the middle, like letting the air out of a tire. Have a rag or two over the valve so gas dont spary in your eyes.
Old Jun 3, 2004 | 04:08 PM
ASIM's Avatar
You guys are great.
Thanks, saved me a bunch of times.
Shoebox, your site is of particular helpfull.
Asim
CaptainObviousI
29
Apr 29, 2021 10:35 PM
PCLZ28
Dec 24, 2015 05:19 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
30thZ4C
Dec 26, 2014 05:09 PM
