Quick question on oil cooler removal.
Old Nov 4, 2005 | 06:27 PM
Durbn4duke's Avatar
I am removing my cooler, what filter should i use now, it looks like there is "2 stubs" in the way of putting an oil filter directly to the part the cooler was hooked to. i hope someone knows what i am talking about. Thanks
Old Nov 4, 2005 | 11:43 PM
Re: Quick question on oil cooler removal.
You need to remove the studs and put normal bolts in there.
Old Nov 5, 2005 | 12:44 AM
Durbn4duke's Avatar
Thanks for the response shoebox, but how do i go about removing them? does anyone have like pictures? what are they there for? Thank you.
Old Nov 5, 2005 | 08:22 AM
Maybe I am confused about what you mean, but this is what it is supposed to look like.
Old Nov 5, 2005 | 11:05 AM
Loadre's Avatar
Use deep well sockets to get the bolts off. You can either use a dremel and cut the extra stud part off or go to the hardware store and find something that matches.
Old Nov 5, 2005 | 08:00 PM
Durbn4duke's Avatar
Guys, i appriciate the responses. I am a little confused still. Here's what I did. I took off the filter and then just turned that piece that the filter threads to until the whole unit dropped. Now I still have a piece to thread a filter to but there are 2 little stud peices hanging down. I don't think a filter will thread all the way up with them in the way. What do I do?
Old Nov 6, 2005 | 01:41 AM
Loadre's Avatar
Use deep well sockets to get the studs off. They have a nut portion past the stud that a socket will fit. Once you get them off you can either use a dremel and cut the extra stud part off flush at the top of the bolt or go to the hardware store and find something that matches.
Got it?
Old Feb 12, 2018 | 10:31 AM
Ryan Fields's Avatar
I have hey LT1 with the oil cooler I have a leak where the oil filter adapter meets the block I removed the two bolts and lines with no luck of getting the oil filter adapter off
Old Feb 12, 2018 | 01:13 PM
What year LT1? There are two different cooler designs.
Shoebox has a diagram of one version:
http://shbox.com/1/oil_cooler.jpg
Old Feb 12, 2018 | 10:28 PM
Did you remove the through bolt (153 in the diagram)?
Old Feb 12, 2018 | 10:49 PM
Both systems come apart the same way. The earlier (93/94) design has a different solid black cooler block with a "Modine" label on it, and the coolant lines are both in a horizontal plane, rather than a vertical plane.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Queens94z28
Dec 20, 2014 09:11 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
97 RedSS
Jun 10, 2003 07:58 PM
