quick question.. found slight oil leak
Old Apr 26, 2006 | 09:09 PM
ttop1986's Avatar
Exclamation quick question.. found slight oil leak
im changing my oil right now, and i noticed some oil on the bottom of my pan. First thing i thought was intake manifold leak, but then i noticed the oil was only on the bottom of the pan, not the back. Took the drain plug out and it seems as if the rubber part of the washer is breaking apart. So im pretty sure the oil leak was from the drain plug, which would explain why its just on the bottom of the pan. Anyways question is, Do you think i could put some rtv to help seal the drain plug or would this be bad to do. Thank you!
Old Apr 26, 2006 | 09:11 PM
2000GTP's Avatar
Re: quick question.. found slight oil leak
RTV will work fine on the drain plug, but considering a new plug doesn't cost much from the dealer, I would just do that.
Old Apr 26, 2006 | 09:36 PM
ttop1986's Avatar
yeah ill use the rtv for now because its 1020 at night and i cant get the part i need. So next oil change ill get it and do it right. thanks
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
96z
Sep 5, 2002 07:53 PM
HuJass
18
Jun 24, 2002 09:19 PM
