383 Piston in a 355?
Old Apr 26, 2006 | 06:27 PM
leadfoot94's Avatar
Does anyone know if I would have any problems running a .030, 5.7" Rod, 3.75" stroke piston, on a stock (3.48") stroke?
Old Apr 26, 2006 | 06:29 PM
jerminator96's Avatar
Re: 383 Piston in a 355?
well yeah, you would need different sized rods. like .27inches shorter.
Old Apr 26, 2006 | 06:46 PM
leadfoot94's Avatar
So the wrist pins are in a different location? I was thinking that it would work because the stroke is smaller with the same rod length.
Old Apr 26, 2006 | 08:02 PM
Well the stroke has to come from somewhere. If rod length is the same and the piston has to move an extra .27 inches.....that would put a pretty good dent in your cylinder heads
Old Apr 26, 2006 | 10:03 PM
Lonnie Pavtis's Avatar
You have it backwards. A 383 piston is shorter assuming the same length rod is used.
The stroke difference of 3.48 vs. 3.75 is .27"
1/2 the stroke is .135". This is how much shorter the 383 piston is.
A 383 piston will not make much compression in a 350 for this reason, nor is it recommended to do this. You either need a different piston or a longer rod (+.135")
For comparison, a stock 400 (where the 383 stroker crank originally came from) uses rods which are .135 shorter & a piston of the same compression height as a 350.
Hope this helps.
Old Apr 26, 2006 | 10:28 PM
leadfoot94's Avatar
Thanks Lonnie, that's what I was looking for.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
