Quick question on dampiner
Old Jun 30, 2008 | 09:42 PM
bombebomb's Avatar
Ordering an ATI one tonite for my build just checking if this one will be alright? Mods for motor in sig. 6200+ rpms.
http://www.thunderracing.com/catalog...2&sid=250#P963
This is what the part says
105-917271 ATI Serpentine Series Damper Assembly with Hub, Aluminum Shell 6-3/4" (Stock Diameter) LT1/LT4 F-Body
Will that be ok? Thanks alot once again guys/gals
Old Jun 30, 2008 | 09:46 PM
FlamingChicken's Avatar
sounds right. been using mine for a while. not 100% on the part number though. might want to consider getting an underdrive though since you are replacing it anyway
Old Jun 30, 2008 | 09:54 PM
bombebomb's Avatar
ah, never seen any underdrives for LT1 on thunder racing's dampiners.
Old Jul 1, 2008 | 12:49 AM
95Blackhawk's Avatar
I suggest using the keyway with a key to hold it in place. Much safer than press fit.
Old Jul 1, 2008 | 05:26 AM
The 6.78" diameter 917271 is the smallest diameter they sell for the LT1.
Old Jul 1, 2008 | 05:40 AM
bombebomb's Avatar
Im asumeing you ment 6.75?
95 blackhawk, ill take a look at it.
EDIT: on my way to buy ARP 7/16 head studs, iv discoverd there is multiple types and I do not know which one I need.
http://store.summitracing.com/egnsea...=KeywordSearch So if someone can point me at the right one, would help alot. Thanks.
I will be useing guide plates if that matters.
Comp cams locks,steel retainers, and spring seats.
Old Jul 1, 2008 | 09:23 AM
rskrause's Avatar
Moderator
The ATI is a good piece. If you are going to the expense of buying one, you should get the most of it. To do so, call ATI and discuss with them which elastomer to use - they have like ten different ones, each is going to be best at around a certain rpm range. To get what you need, you may have to order directly from them which will cost a bit more.
If I were buying a generic damper, I'd go with Fluidampr as it is not as rpm specific, though it is a bit less effective.
Rich
Old Jul 1, 2008 | 10:39 AM
bombebomb's Avatar
Rich
That would be a good idea, however kind of need this quickly, and kinda went over budget as it is lol. Any info on what studs?
Old Jul 1, 2008 | 02:33 PM
bombebomb's Avatar
Stud info anyone? Need to order by 5:30~ thanks!
Just need stock rocker stud lenght I guess.
EDIT# 563
Search feature found something
Arp-134-7103
ordering now.
Thanks for everyones help, yet again.
Old Jul 1, 2008 | 05:14 PM
Originally Posted by bombebomb
Im asumeing you ment 6.75?....
No. I meant exactly what I typed. Did you take the time to look at the ATI spec sheet? What do they show the diameter as?
http://www.atiperformanceproducts.co...ts/damserp.htm
Old Jul 1, 2008 | 08:42 PM
bombebomb's Avatar
http://store.summitracing.com/partde...5&autoview=sku I thought this one was small? I must be reading it wrong.
Old Jul 2, 2008 | 05:27 AM
If you choose to believe Summit over the manufacturer......
Old Jul 2, 2008 | 10:32 AM
bombebomb's Avatar
Good point. Summit is why I was confused and second guessing your post, which I should know by now not to do thanks again!
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
