Quick Question
Old Jan 21, 2006 | 10:23 PM
White95LT1's Avatar
Quick Question
I own a 95 Z, A4, bone stock...shuts off at 115.. I had always thought Z's didn't shut off that soon much less shut off at all. ...Just curious is all..
Old Jan 21, 2006 | 10:30 PM
KillWhitey's Avatar
Re: Quick Question
I think they put fuel shut-offs in early LT-1 Z28's that had cheaper tire options with lower speed specifications.
You can write down your Vehical Identification Number and take it to the dealership and they can tell your car came with the cheaper tires.
Tim
Old Jan 21, 2006 | 10:32 PM
White95LT1's Avatar
Re: Quick Question
Programmer still have the same effect to raise/remove it?
Old Jan 21, 2006 | 10:35 PM
cdb95z28's Avatar
Re: Quick Question
If it came with the Goodyear GSC 245/50ZR16 tire as an option, there is no speed limiter. And you get the 150mph speedo. I`ve had mine to 140
Old Jan 21, 2006 | 10:37 PM
White95LT1's Avatar
Re: Quick Question
yeah...well mine deff. shuts off...already checked that out..lol..but yeah it came with Goodyear's....and that size...but no luck with reaching over 115mph....gets annoying trying to play catch up
Old Jan 21, 2006 | 10:52 PM
cdb95z28's Avatar
Re: Quick Question
Did You look at the Service Parts ID sticker in the glove box?
QLC is for the 245 Goodyears
QMT is for the 235 Goodyears/115 speed limiter.
Did you buy the car used? Maybe a dealer in the past did a computer recalibration and screwed up?
Old Jan 21, 2006 | 10:53 PM
KillWhitey's Avatar
Re: Quick Question
The tires would be the same size with just a different speed rating
"Programmer still have the same effect to raise/remove it?"
yes
Old Jan 21, 2006 | 10:55 PM
cdb95z28's Avatar
Re: Quick Question
...or maybe because it`s an auto Is it possible GM did things differently with the autos???
Old Jan 21, 2006 | 11:03 PM
cdb95z28's Avatar
Re: Quick Question
In `94 there were no other 245 tires. In `95 you could get a 245 all season as this was the first year for traction control. In `94 the standard tire on Z28s was the 235/55R16 "touring". The "performance" tire was an option-245/50ZR16. And that was only available on the coupes.
Old Jan 21, 2006 | 11:13 PM
White95LT1's Avatar
Re: Quick Question
alright...thanks people...just wanted to get info before spending money on a programmer..as for it shuting off at 115 cause it's an auto..no..buddy of mine has the same yr model with a A4 and it doesn't shut off...and Yeah I bought it used..only had it since late Oct..havn't had time to do anything do to the Hurricane..
Old Jan 21, 2006 | 11:22 PM
Re: Quick Question
Its not because its an auto. Its determined by the speed rating of the tires that came on the car from the factory, as several people have already explained above. Doesn't matter if its a coupe, a t-top, an A4 or an M6.... if it doesn't have the Z-rated tires, it has a fuel cut speed limiter built into the PCM. The limit varied over the years, and ranged from 112-117mph.
If you look at the program for the cars with the Z-rated tires, there is a number entered into the speed cut-off field, but its "255" = the maximum number for an 8-bit field.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
