Quick oil cooler help please
Old Sep 12, 2007 | 07:22 AM
  #16
Originally Posted by wrd1972
None of the LT1 Corvettes had an oil filter so from that standpoint they are not essential.
...[/url]
I'm sure you meant cooler not filter.
BTW, the cooler was dropped as an option from the LT1 f-bodies in 1996.
Old Sep 12, 2007 | 10:00 AM
  #17
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
The primary reason I'm planning to remove my oil cooler is because I believe it's necessary for a Kooks header installation. I also think my cooler may have plugged a little bit upon getting my car running after having sat in storage for an extended period. I know that the oil pressure dropped significantly within 30-60 seconds of getting the car running. I replaced my sending unit, which helped a little. I also mounted a mechanical oil pressure gauge this past week, which seems to indicate there could be some issues with the gauge in my car. The mechanical gauge would read as high as 50psi, but the gauge in my car wouldn't really get any higher than 40psi. Afterwards, I was feeling pretty good about my pressure. But I guess lower oil pressure is fairly common on these engines. I just remember my car running well over 40psi before I parked it for 6 years. I didn't really want to get headers and an exhaust if there could be some internal issues with my engine.
Back to the oil cooler, I believe I'm clear on the bypass hose, GM PART # 10197675, and the bolts to replace the studs where the current cooler/adapter are mounted, GM PART # 3951644.
I'm just trying to confirm whether a new adapter, GM PART # 3952301, is required. If so, I'm assuming it would work regardless of model year. I haven't thoroughly reviewed my service manuals yet, but perhaps this is covered.
Old Sep 12, 2007 | 11:34 AM
  #18
wrd1972's Avatar
Yup, that is what I meant.
Old Sep 12, 2007 | 11:37 AM
  #19
BTC's Avatar
BTC
Does this mean I should put the filter back on my car?
Old Sep 13, 2007 | 10:00 AM
  #20
BTC's Avatar
BTC
I think I'm just going to buy the adapter. Better to have it and not need it, than to need it and not have it. All of the parts listed shouldn't be more than 40 bucks. Using the adapter shoebox mentioned seems to be the preferred method of deleting the oil cooler.
Anyone running Kooks with the adapter in place?
Old Sep 13, 2007 | 11:21 AM
  #21
Yes, you should always use a filter.
Old Sep 13, 2007 | 11:44 AM
  #22
BTC's Avatar
BTC
I was just joking about the filter. I'm no Mr. Goodwrench, but I'm pretty **** about keeping an oil filter on my cars.
Old Sep 13, 2007 | 12:14 PM
  #23
GM clearly stated that the reason the Corvette LT1 did not have an oil cooler was because the Corvette engines were filled with Mobil 1 synthetic at the factory, and the synthetic oil was not degraded as much by higher operating temperatures, compared to conventional oil.
Old Sep 13, 2007 | 12:58 PM
  #24
BTC's Avatar
BTC
Was Mobil1 the factory fill in Z28's? I'm just curious because that's what I've always put in my car beginning with the initial oil change.
Old Sep 13, 2007 | 01:59 PM
  #25
No, it was not.
Old Sep 14, 2007 | 12:25 AM
  #26
DrewHMS97SS's Avatar
I would think that part of this mod is cleanup. The aluminum lines look just as nice as the air pump connection between the driver and passenger side.
Old Sep 15, 2007 | 01:42 AM
  #27
blackgold84's Avatar
thanks fo the read, glorious interweb!
dylan1303
May 22, 2015 12:24 PM
KYWes
May 15, 2015 09:10 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
blkWidow
Apr 20, 2015 09:27 AM
97 RedSS
Jun 10, 2003 07:58 PM
