Quick oil cooler help please
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
The primary reason I'm planning to remove my oil cooler is because I believe it's necessary for a Kooks header installation. I also think my cooler may have plugged a little bit upon getting my car running after having sat in storage for an extended period. I know that the oil pressure dropped significantly within 30-60 seconds of getting the car running. I replaced my sending unit, which helped a little. I also mounted a mechanical oil pressure gauge this past week, which seems to indicate there could be some issues with the gauge in my car. The mechanical gauge would read as high as 50psi, but the gauge in my car wouldn't really get any higher than 40psi. Afterwards, I was feeling pretty good about my pressure. But I guess lower oil pressure is fairly common on these engines. I just remember my car running well over 40psi before I parked it for 6 years. I didn't really want to get headers and an exhaust if there could be some internal issues with my engine.
Back to the oil cooler, I believe I'm clear on the bypass hose, GM PART # 10197675, and the bolts to replace the studs where the current cooler/adapter are mounted, GM PART # 3951644.
I'm just trying to confirm whether a new adapter, GM PART # 3952301, is required. If so, I'm assuming it would work regardless of model year. I haven't thoroughly reviewed my service manuals yet, but perhaps this is covered.
I think I'm just going to buy the adapter. Better to have it and not need it, than to need it and not have it. All of the parts listed shouldn't be more than 40 bucks. Using the adapter shoebox mentioned seems to be the preferred method of deleting the oil cooler.
Anyone running Kooks with the adapter in place?
GM clearly stated that the reason the Corvette LT1 did not have an oil cooler was because the Corvette engines were filled with Mobil 1 synthetic at the factory, and the synthetic oil was not degraded as much by higher operating temperatures, compared to conventional oil.
Was Mobil1 the factory fill in Z28's? I'm just curious because that's what I've always put in my car beginning with the initial oil change.
