Please Help
Please Help
About two weeks ago I noticed a slight miss under light acceleration. I pulled it all apart and found #6 plug wire melted to the header. Installed a new set of wires and made sure the wires were not touching headers. I still have the miss. Do you think do to the burnt wire could it of damages opti causing the miss? Any input would be very helpfull. Car has 36000 miles on it.
If you can get the car scanned with a unit that has "GM enhanced parameters", they can actully call up the misfire count for each individual cylinder. That should point you in the correct direction. When it misfires, does the SES light flash?
