Quick idea's - crank no run
Old Oct 31, 2007 | 10:53 AM
  #16
blue89rs's Avatar
HOLY CRAP! The stealership wants $667.14 for a new distributor. Isn't that a bit much? At that price, I'm going to get the base unit from CarQuest for $230 and reuse the cap/rotor. Can anyone tell me if the Opti-I and Opti-II are interchangeable (except for the plug)?
Old Nov 1, 2007 | 10:29 AM
  #17
blue89rs's Avatar
It was full of rust and metal shavings. The opti wheel was covered in rust dust, so was the cap and rotor. Water was probably getting in through the input shaft and fouling things up. No doubt it was the problem.
Old Nov 1, 2007 | 04:49 PM
  #18
You can not switch the vented and non-vented Optis, unless you get a new timing set, timing cover, harness and a cam with a larger pilot hole and a longer dowel pin. Here is the info:
http://para.noid.org/~muttvette/opti.html
Spend some time with the "search" feature. There is deep (~50%) discount pricing available on genuine GM parts, and the sources are regularly posted here. Shoebox has part lists, part numbers, part sources, etc:
http://shbox.com/1/4th_gen_tech1.html
http://shbox.com/1/Parts.htm
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
What did you mean when you said:
....The wires that I have don't match the 95 wires for the opti......
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
97SSdude
Dec 31, 2014 07:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Absolute Z28
Jul 19, 2002 02:21 PM
