Quick Hooker LT question
Old Jun 24, 2004 | 10:57 AM
drewstealth's Avatar
My #1 primary slip fit is leaking and hooker told me to try some High Temp Copper RTV on it. I'm gonna take off the #1 primary and put it in the inner tube and then slid it on. I was just wondering if i could do this with the rest of the header in place and just removed the #1 primary or if i got to unbolt the whole drivers side header. Also i have Percy dead soft aluminum gaskets. Its not gonna mess up the gaskets if i do this is it?
Old Jun 24, 2004 | 02:05 PM
LWillmann's Avatar
I did it with the rest of the header in place and bolted down.
Old Jun 24, 2004 | 02:07 PM
IllusionalTA's Avatar
You'll be fine w/ taking it off.. It should be able to be wiggled out.. You might however need to loosen some of the header bolt's to help rotate it away and out.. Throw a thick layer of Copper RTV.. And i mean THICK!!! Inside the primary the slip fit tube goes into.. Not the slip fit itself.. But you can coat that liberally as well.. The more the better.. Then let sit for 24 hours before starting.. You should be ok for a lil while..
Old Jun 24, 2004 | 03:27 PM
How long do you think the copper RTV will last. I don't want to be doing it every 1,000 miles or so. Also if it starts to burn off do you think that can ruin my o2 sensors?
Old Jun 24, 2004 | 03:55 PM
LWillmann's Avatar
I've got 7,000 miles since I did mine, seems OK to me.
Old Jun 24, 2004 | 05:12 PM
Bersaglieri's Avatar
Excuse me for interupting but I am going to put on some LT's soon, what kinda of 1/4 or Dyno numbers are you guys putting up with CAI/LT/Catbacks? Thanks. I am considering AS&M also even though I have the Hookers sitting here...something about those AS&M I just cant get them off my mind.
-Dustin-
Old Jun 24, 2004 | 05:34 PM
Loadre's Avatar
Bersaglieri, personally I would sell the hooker and get Pacesetters. Install was a breeze.
Old Jun 25, 2004 | 03:47 PM
anybody else know if the Copper RTV starts to burn off will it ruin my o2's?
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
ModdedNerd
Jan 1, 2015 10:56 AM
