Fuel pump replacement
Old Jun 25, 2004 | 02:26 PM
got8?'s Avatar
how much work is involved in replacing a fuel pump
Old Jun 25, 2004 | 02:32 PM
1993Z28LT16SPD's Avatar
It's a pretty heavy job - you really need a lift too. I had it done on my 93 Z28 because it was too much to take on. Basically, you have to take down the real axle, take off the exhaust system then restle with the tank. I think the part was about $350 and I had to pay for 6 or 7 hrs of labor - set me back $800 or so.
Old Jun 25, 2004 | 02:35 PM
gamecockfan04's Avatar
Not to bad if you pull the carpet back on the top of the hatch area and cut a hole(carefully) and go at it from the top of the tank. Otherwise youll have to remove the exhaust and drop the tank, which would be a major PITA. I went in from the top and it was pretty easy and you would never be able to tell unless you pull the carpet back.
Old Jun 25, 2004 | 02:53 PM
Heres a link to help out with the "through the trunk/hatch" method I used: http://www.fbody.com/cgi-bin/lt1/rea...=177776#177776
Old Jun 25, 2004 | 03:35 PM
got8?'s Avatar
WOW!! Thanks that makes things much easier thanks alot!!
Old Jun 25, 2004 | 04:50 PM
RamAir95TA's Avatar
You're welcome.
Scottyboy
Feb 11, 2015 10:28 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
