quick fuel question
Old Oct 26, 2006 | 11:39 PM
Daniel6718's Avatar
quick fuel question
with a walbrough 255 intank pump and a hotwire kit, cc306 stock longblock, plus 100 shot...
if im running out of fuel what do yall do? an external inline pump?
Old Oct 26, 2006 | 11:45 PM
blksunshine's Avatar
fuel injectors? are you runing a dry or wet shot?
Old Oct 27, 2006 | 12:56 AM
Daniel6718's Avatar
wet
Old Oct 27, 2006 | 09:06 AM
How do you know you're running out of fuel? A healthy 255LPH pump should be capable of supporting 700+ flywheel HP.
Old Oct 27, 2006 | 11:02 AM
Daniel6718's Avatar
thats what i thought, i dont know for sure yet, i know the filter is new, fpr seems to work fine as of last time i checked it, 2 weeks ago, dont know what else could cause it...
Old Oct 27, 2006 | 11:13 AM
2000GTP's Avatar
Has your car been tuned for the cam? As Injuneer said, that fuel pump is more then capable of feeding a CC306 cam and a 100 shot of nitrous.
Old Oct 27, 2006 | 11:55 AM
I still don't understand how you determined (or why you even suspect) it running out of fuel - is it losnig power, running lean, backfiring, etc??? All you need to do is put a pressure gauge on it and take it up to max load/rpm. If the pressure stays above 40psi, its not a fuel pump problem.
Old Oct 27, 2006 | 01:16 PM
Daniel6718's Avatar
poping on n20, i need a fuel pressure gauge, cant find one....GRR, ill let yall know soon
Jan 23, 2015 01:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
Brady
Jul 29, 2002 10:30 PM
