any data on cold air intakes helping power in lt1
Old Oct 26, 2006 | 03:53 PM
rage366's Avatar
i tried a search but i wasnt getting what i needed...so, here it goes.
with a big cam and higher compression, does an lt1 really need an aftermarket filter and the replacement of the intake hose?
thanks.
Old Oct 26, 2006 | 05:45 PM
rage366's Avatar
wow...22 views and no replies?
Old Oct 26, 2006 | 05:47 PM
Unertl42's Avatar
CAI=More Air, which is needed for more HP, so it won't hurt
Old Oct 26, 2006 | 05:50 PM
rage366's Avatar
it's not quite that simple. some of the research that i did previous to this thread indicated (based on dyno #'s) that k&n filters dont really add any hp...
wish it was that black and white.
Old Oct 26, 2006 | 05:54 PM
LenT1's Avatar
Why dont you have someone with 600rwhp put the stock intake back on and see what happens.
Old Oct 26, 2006 | 06:02 PM
rage366's Avatar
well, i dont thnk that someone with a 600rwhp will be using a stock tb...
Old Oct 26, 2006 | 06:09 PM
kyle97's Avatar
I think the easiest way to find out is to log your MAP during a few WOT runs. Any restrictions from the filter, air passage, MAF, TB, or intake will show up as a vacuum at WOT.
If you change out the filter and see a decrease in the WOT vacuum (ie an increase in MAP at WOT) then it has improved the airflow. How much hp that translates into, i dont know.
Old Oct 26, 2006 | 07:39 PM
dre2013's Avatar
my car is modded but still has the stock air intake...i still do not know why the previous owner didnt put one on, but I definetly am asap.
Old Oct 27, 2006 | 10:16 AM
DrivingZiggy's Avatar
Okay, I can't give you numbers, but I can give you my experience.
First I installed my Flowmaster cat-back. I was disappointed. It was louder, but I didn't notice any gain. In fact, I later cruised on over to Thunder Racing and the guy I spoke to there said that they had just dynoed a before and after and that they actually lost 7 HP with the Flowmaster.
Then I added my SLP headers and Y and "bypassed" the cat. This made a wonderful improvement. I could feel the SOP (seat of the pants) difference and it made the even sound better. I didn't like the sound of the cat-back by itself, but with the new mod, the sounds "woke up". And I could feel the difference.
Most recently, I got my Ultra Z hood then a Ram Air intake. This seemed to make as much improvement as the headers! I was very impressed with my gains.
But, I don't have any dyno numbers for you. All I can tell you is that I can feel it in the seat of my pants and am finding it difficult to get any traction.
Old Oct 27, 2006 | 10:45 AM
MyShibbyZ28's Avatar
You said nothing about keeping the TB stock with a big cam, and what does a TB have to do with the original question anyways? On a stock car a CAI is not going to do much. On a 600 hp car, regardless of TB, it is going to do something. I don't know if anyone has these at their auto stores, but one here had a set up where you could change from a paper filter and a K&N filter. There was a fan behind it, and you could feel the difference in air flow (just put your hand infront of it). Not some small difference either, it was a very big and noticeable change. I think it never hurts to have one.
Old Oct 27, 2006 | 12:05 PM
On my totally stock engine, brand new in 1994, the first two mods I did were the Callaway Honker CAI (same as the Moroso) and the Borla catback. Those two changes together, on a totally stock engine, gained me 3/10's in the 1/4-mile, verified with a Vericom accelerometer, and corrected for differing ambient conditions.
Note that the effective CAI's are more than an aftemarket filter and a replacement of the "hose". They typically relocate the filter completely outside the engine compartment, have a large cross-sectional flow area, and minimize the sharp turns of direction that the pinched stock ducting makes.
I think the reason you didn't get much in the way of a response intitially is because the CAI is a slam-dunk on these cars.... probalby designed that way by GM so the F-Body LT1 would not make as much HP as the Corvette version...
Old Oct 27, 2006 | 12:22 PM
rage366's Avatar
http://web.camaross.com/forums/showt...old+air+intake
the second page is interesting...
Old Oct 27, 2006 | 02:13 PM
miaminick's Avatar
dude...that thread is in reference to performance filters, not CAI
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
ezcheeze15
Aug 8, 2002 12:27 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
