Quick Carb Swap:can It Be Done?
Old May 8, 2004 | 11:03 AM
OBDIICamaro's Avatar
Ok I am basically throwing around the Idea of swapping the carb setup on there. I basically would have to just buy the intake since I can borrow everything else needed. I would like to get some before and after numbers and see what it would get us.
My questions are.
Can I retain the stock opti unit or do I have to go to distributor.
What do I do for Fuel system? I dont think that you can regulate the stock setup pump for a carb setup because it will kill it. What are my choices?
That is basically it, those are my 2 main questions. Please no bashing like it has started on other threads. I want to try something different, if it doesnt work then I will put it back to the fuel injection setup.
Old May 8, 2004 | 03:07 PM
madwolf's Avatar
There is a timing cover offered for the LT1 with the opti hole blocked off and the intake comes with a provision for a traditional distributor. You will not be using the opti or the computer in other words. Can't tell you much about the fuel pump though.
Old May 8, 2004 | 03:36 PM
Is there a way you can still utilize the opti or no?
Old May 8, 2004 | 05:03 PM
chy20k1's Avatar
good luck if you gotta take the distributer out if you go to a carb setup. gonna have to lower the motor to get at it
Old May 8, 2004 | 05:04 PM
1984camaroz28's Avatar
why whould u wana go carbed anywayz????
U could run a inline fuel pump and a regulator they run. thats what im runing on my BB
Old May 9, 2004 | 12:13 PM
Also I forgot to ask, can I still use the 4l60 with no shifting problems?
Old May 9, 2004 | 12:15 PM
GreenDemon's Avatar
I'm assuming you mean the 4L60E? If so, then I doubt it. Too much electronics. You'd probably get it in there, put the sucker in drive and it would never shift... I think a 4L60 might work though, out of the 93s, 700R4s from previous years..
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Kawi
Sep 28, 2015 09:01 AM
NewsBot
Sep 14, 2015 09:20 AM
