Quick Carb Swap:can It Be Done?
Ok I am basically throwing around the Idea of swapping the carb setup on there. I basically would have to just buy the intake since I can borrow everything else needed. I would like to get some before and after numbers and see what it would get us.
My questions are.
Can I retain the stock opti unit or do I have to go to distributor.
What do I do for Fuel system? I dont think that you can regulate the stock setup pump for a carb setup because it will kill it. What are my choices?
That is basically it, those are my 2 main questions. Please no bashing like it has started on other threads. I want to try something different, if it doesnt work then I will put it back to the fuel injection setup.
My questions are.
There is a timing cover offered for the LT1 with the opti hole blocked off and the intake comes with a provision for a traditional distributor. You will not be using the opti or the computer in other words. Can't tell you much about the fuel pump though.
I'm assuming you mean the 4L60E? If so, then I doubt it. Too much electronics. You'd probably get it in there, put the sucker in drive and it would never shift... I think a 4L60 might work though, out of the 93s, 700R4s from previous years..
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
