quick cam install ? .. do you have to take the intake manifold off even if
Old Feb 13, 2004 | 01:41 PM
sc93's Avatar
you aren't replacing the lifters?
I would assume you do, to take the lifters out and also for the oil pump drive gear.
but if not necessary, I don't want to have to pull the manifold off.
Old Feb 13, 2004 | 01:43 PM
96ta(nick)'s Avatar
Yes you have to or the lifters will fall down into the block when you pull out the cam.... oh and the oil pump gear will keep you from even pulling the cam out.
Old Feb 13, 2004 | 01:45 PM
hsyr's Avatar
I've never installed a cam before but if you were to remove the old cam, wouldn't the lifters fall down making it not possible to install the new cam unless you find a way to keep them held up?
Old Feb 13, 2004 | 01:51 PM
sc93's Avatar
Thanks guys.
That's what I thought Just making sure
Old Feb 13, 2004 | 06:54 PM
9T4LT1's Avatar
I was under the assumption that the lifters were spring loaded and all you had to do was loosen the rocker arms to get the lifters to raise out of the way of the cam. I could be wrong........wouldn't be the first time
Old Feb 13, 2004 | 07:00 PM
Yeah, better do a little more study on the engine design.
Old Feb 13, 2004 | 07:16 PM
97 WS6 T/A Conv's Avatar
Incorrect. The lifter has a spring but it's contained within the lifter body itself.
You MUST remove the lifters and the oil pump gear from the block to remove the cam and that means pulling the intake.
Old Feb 13, 2004 | 09:17 PM
96lt1Camaro's Avatar
since we are talking about the intake. Whats the biggest size TB the stock lt1 intake can hold without porting?
Old Feb 13, 2004 | 09:23 PM
EbeZ28's Avatar
Someone call an Air Marshall!!! This threads being hijacked
Answer = 52mm (pretty sure anyway)
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
