Questions
Old Sep 19, 2007 | 06:46 PM
VicsROC's Avatar
Questions
I have a 94 Z28, automatic. When I try to get on it a little bit it doesn't respond when engine is pulling i.e., on hills. A little better on flats not much though. Any thoughts?
Old Sep 19, 2007 | 09:08 PM
seawolf06's Avatar
Have you done any maintenance recently? Does the motor spin up and it just doesn't move, or does it bog?
Sounds like it could be fuel filter, spark plugs, wires, air filter, dirty throttle body, any number of things really.
Old Sep 19, 2007 | 11:12 PM
mrmint69's Avatar
How many miles, what have you done to the engine & do you have a check engine light? I would make sure you have done the routine maintenance and then look to things like exhaust leaks, worn out engine and so on. Also how long have you owned the car and when did it start getting gutless?
Old Sep 21, 2007 | 12:56 PM
VicsROC's Avatar
Well I just bought the car. This is my first LT1 camaro, so don't know much about them. The mileage is about 128,000. I haven't done much to it yet. I just recently had the exhaust leaks repaired so that should be fine. I guess I'll start with a basic tune up and see what happens. Thanks for the input guys>
Old Sep 21, 2007 | 02:22 PM
Projectcam94's Avatar
service engine light on?
Old Sep 22, 2007 | 06:29 AM
mrmint69's Avatar
I would have the codes read and go from there. It could be dirty air filter, maf or just plugs and wires. I would replace fuel filter also.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
