Question for those with Vortech elbow
Old Jun 30, 2003 | 03:32 PM
Don't Look Back's Avatar
I'm planning on replacing my torn stock elbow with a satin Vortech aluminum one for 2 reasons: One, it won't tear, and two, I want the intake to be rounded without bumps (so the 1LE is out) My question is: Are these elbows a direct replacement with plumed holes for the different wires and sensors or do they have to be drilled?
Old Jun 30, 2003 | 06:52 PM
Teal94Z's Avatar
if you have a vented opti, you may have to drill a small hole, otherwise its bolt up and go
Old Jun 30, 2003 | 07:37 PM
leadfoot94's Avatar
Teal94Z
That's not totally true, you have to thread your Air Intake Temp. Sensor so it can screw into the elbow, and you may have to cut the length down depending on which CAI you have so it fits good.
Old Jun 30, 2003 | 08:26 PM
ScreamingChicken's Avatar
ine bolted in fine, but i did have to mess with the Air Intake Temp. Sensor a bit
Old Jun 30, 2003 | 08:52 PM
95TA8280's Avatar
I heard some people said that with the Vortech elbow they had to mess around with their CAI......I don't have it so I can't confirm.
Old Jun 30, 2003 | 08:58 PM
MZK4252's Avatar
I had to cut a couple inches off the elbow to get my MOroso to fit. YOu also have to drill and thread a hole for the vented opti line, and then tap the IAT sensor. None of this takes more than a few minutes if you have the tools.
Old Jun 30, 2003 | 09:42 PM
1msfyter's Avatar
Heres what I did: I had to cut 1 1/2" off the elbow(SLP cai)
I capped the IAT hole and relocated forward.
I drilled a hole in the corner of the elbow for the opti vent
The IAT I installed in the air pump outlet and used a mini K&N
IAT relocated:
http://www.bealer.org/iatrelocate.jpg
Elbow:notice no wires for the IAT:
http://www.bealer.org/bmrrad3.jpg
Old Jun 30, 2003 | 11:44 PM
1msfyter's Avatar
Painted high temp and baked
Old Jun 30, 2003 | 11:56 PM
Thanks guys. I assume this work needs to be done to the Trick Flow elbow also?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
lt1matt
Mar 21, 2015 07:35 PM
Mike94ZLT1
Jul 31, 2002 01:50 AM
dansam
Jul 20, 2002 01:10 PM
