question for harmonic balancer
Old Aug 9, 2009 | 11:10 PM
Garylisko's Avatar
trying to remove the harmonic balancer to replace the cap and rotor, do i need a pulley puller, or is there another method? thank u
Old Aug 9, 2009 | 11:48 PM
sick9lt1's Avatar
there is a tool you have to have to do it. i cant think of it but i got one from autozone call them they will know.
Old Aug 10, 2009 | 12:07 AM
To replace the cap/rotor, you do not have to remove the entire harmonic damper. You leave the hub on the crank, and just remove the three bolts that hold the pulley/damper on the hub. When it left the factory, that was a simple slip fit, and the pulley/damper would fall off when the bolts were removed. But with many years of rust, it usually takes a 3-jaw puller to remove the pulley/damper from the hub,
Courtesy of Shoebox:
http://shbox.com/1/pull_pulley.jpg
On the 96/97 pulley/damper, there are threaded holes in the "spokes" for pulling the damper.
Why not add a "signature" with basic info about your car - year, model, engine, tranny and any major mods? That way people don't have to guess to provide you with the correct answers.
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Mar 7, 2015 09:21 AM
Newgmman
Feb 25, 2015 02:53 PM
cyteone
Feb 7, 2015 06:04 PM
smokin5s
Jul 24, 2003 10:47 PM
