Question about my Cam/Rockers/Springs
Old Jun 23, 2006 | 08:33 PM
Mike96z's Avatar
Alright my 388 LT1 has this valve trane setup.....
CC468 .584/.579 (specs w/ stock rockers)
1.6 Ratio Comp Cams Roller Tip Rockers
Crane Cams 10308 Dual Valve Springs
LT4 Lifters (weak point)
Comp Cams Magnum Pushrods (Hardened)
Alright, these are the things I wanted to know.....
Cam: what's my lift with 1.6 Rocker????
Springs: what's the lift limit on these??? (Can't find specs anywhere, I think it's .600/.600)
Lifters: What's the best set of lifters I can put on this thing? Haven't heard anything good about Comp "R"s)
Those are things I need to know, some people say the 10308 springs walk but they don't on my car and have no prob taking it up to 150 mph.
Thanks for any input.
Old Jun 23, 2006 | 08:48 PM
arcticz28the383's Avatar
Re: Question about my Cam/Rockers/Springs
.622/.617
Old Jun 23, 2006 | 08:52 PM
MEAN LT1's Avatar
There nothing wrong with the lifters you have. The oem liftes will do just fine for your setup. Now if you were to upgrade lifters I would go with some Morels' or some Rhodes lifters. Other than that everything looks good.
Old Jun 23, 2006 | 11:29 PM
1racerdude's Avatar
Call Crane for spring spec.
Stock lifters will be fine if in GOOD shape.
The lift is right as stated by arcticz
Old Jun 24, 2006 | 11:42 AM
clai9's Avatar
The lift of the Comp CC468 .584/.579 is with 1.6 rockers.
Old Jun 24, 2006 | 11:56 AM
89TramsAmGTA's Avatar
I agree. The lift is with 1.6 rockers.
Old Jun 24, 2006 | 01:26 PM
Mike96z's Avatar
No check the specs online, and also I have the CAM CARD and it says that's the lift with stock rockers. Here's proof............
http://store.summitracing.com/partde...5&autoview=sku
As stated:
Intake Valve Lift with Factory Rocker Arm Ratio: 0.584 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.579 in.
Valve Lift with Factory Rocker Arm Ratio: 0.584 int./0.579 exh. lift
Old Jun 24, 2006 | 01:31 PM
Ok let's go this route. If you have the cam card what is the lobe lift? Then multiply that times 1.5 and then 1.6 and see what you come up with.
Old Jun 24, 2006 | 04:06 PM
Mike96z's Avatar
The card reads:
Lobe lift: 389/386
Figuring as you said: 1.5 Ratio = .584/.579
1.6 Ratio = .622/.618
If I chose 1.7 Ratio = .661/.656
Old Jun 24, 2006 | 10:58 PM
clai9's Avatar
Here is a link to Comp cam. Scroll down to the XFI cams and you see that they're using 1.6 rockers for that lift.
http://www.compcams.com/technical/Ca...07/168-169.pdf
Old Jun 24, 2006 | 11:47 PM
Mike96z's Avatar
Well I guess that's what's bad about summit, they always have FALSE descriptions of their products. Thanks for clearing that up, but even the cam card says that.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
