Question about Jethot Lts with emissions
Old May 22, 2006 | 10:42 PM
Huntr1117's Avatar
Question Question about Jethot Lts with emissions
I'm about to get a used set of Jethot Lts with emission fittings for my 96' and I heard something about the AIR connections not fitting. Anyone know about this and what do I need to get the install to work? Is it some sort of coupling?
Old May 23, 2006 | 12:36 AM
sko_spo's Avatar
Re: Question about Jethot Lts with emissions
I have a set on my car and the air fittings did not match up. The stock air fittings were to small, I called up JetHot and they told me the size of the coupler. I forgot what size it was but you can buy them at Home Depot. Now I have question myself , Does anyone know what size of bolt i need to thread into my EGR pipe fitting on the headers?
Old May 23, 2006 | 04:50 PM
96arcticwhite's Avatar
7/8 -18 is the size on my AIR fittings on my Jet hots. http://www.dormanproducts.com/ will have them, look under oil pan plugs.
They are not pipe thread or metric. At least on my headers that's true.
Old May 24, 2006 | 09:44 AM
Huntr1117's Avatar
I'm not trying to plug them. I just talked to Jethot and they told me that they only had a problem on the 97' models and the late production 96' models. He said that I need to check them first and if there is a problem to call them back. Anyone know what part I'll need?
Old May 24, 2006 | 11:11 AM
The 93, 94 and some 95 use the larger M22 thread (or something that's close enough for M22 to fit - they worked in my stock manifolds, in my JBA headers and in my AS&M headers). Some 95's, and the 96 and 97 cars have the smaller diameter fittings.... 7/8" or M18 seems to be a decent approximation. If your headers have the larger M22 size openings, you would need a "bushing" to allow your smaller fittings to fit in the larger hole.
maybe2fast
Mar 16, 2015 11:59 AM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
mritter1965
Exhaust System
Feb 15, 2015 07:31 AM
donot_4get
Sep 14, 2002 08:03 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
