Question about Fabricated Valve Covers
Old May 17, 2009 | 07:47 PM
1993Fast_Z's Avatar
i just recently bought a pair of Fab'd. Valve Covers for my LT1...i noticed that they dont have holes for breather or PCV..will this be ok? or should i make a hole?
Old May 17, 2009 | 07:54 PM
MachinistOne's Avatar
You need the PCV and breather.
Old May 17, 2009 | 11:23 PM
The PCV valve goes into the side of the intake manifold. The connection on the passenger side valve cover is the air vent line, that flows clean air from the throttle body, into the valve cover, through the crankcase and lifter valley, and out through the PCV valve. You need the vent line or a breather, as noted in the post above. The stock valve cover has a small baffle under the hole for the vent line, to limit the amount of oil the get into the vent line, if the PCV valve can't handle the blowby, and it starts to flow backwards through the line to the throttle body.
Old May 18, 2009 | 05:45 PM
1993Fast_Z's Avatar
so i should drill holes with a hole saw bit, install grommets and put the PCV and a breather then...correct?
Old May 18, 2009 | 08:18 PM
Exactly how I do it, plenty of lube(wd40) and slow speed with even pressure - deburr the hole and put in your grommets.
Old May 22, 2009 | 01:45 PM
1993Fast_Z's Avatar
now i have another problem...i got to looking at these valve covers...i dont think it is gonna clear the Alternator..it is a 93...any answers on this?
Old May 22, 2009 | 02:52 PM
SnakeOiler's Avatar
ballpein hammer
Old May 22, 2009 | 05:36 PM
With some aftermarket covers, you can gain enough clearance by grinding down the bottom of the alternator where it contacts the cover.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
Jul 4, 2005 05:00 PM
