Tps?
Old Mar 19, 2009 | 03:39 PM
henryz28's Avatar
Tps?
I have been having a problem with my tps. It only happens when I go wot. After I go wot the car throws a code and shifts incorrectly. The code is P0122 tps low voltage code. I have set the tps to .68v at 0% throttle but it sill throws the code at wot. I am thinking the tps is bad, it also Idles funny sometimes; sometimes the idle is high and other times the idle is low.
Old Mar 19, 2009 | 04:39 PM
Monitor it with a scanner or meter while you run it through the operating range. You only need the key ON-engine does not have to be running.
Old Mar 19, 2009 | 04:43 PM
joeSS97's Avatar
Change it. It has a dead spot,prolly just off idle. Like $30
Old May 22, 2009 | 04:40 PM
kkollwitz's Avatar
My 2002 Z28 has been idling high, say 1300rpm when it used to idle at 800. Got the check engine light, had the code read, it's the TPS. It looks like a very straightforward replacement job...is there more to it than just taking off the old one and putting on the new one?
Old May 22, 2009 | 05:27 PM
P0122 sets when the TPS voltage drops below 0.20V. That would indicate a dead spot, as mentioned in the post above, or a wiring problem.
kkollwitz:
You are in the wrong forum, this is LT1 Tech, you have an LS1. And its generally not a good idea to tack your problem onto someone else's thread, possibly adding confusion as to whom someone is responding to. Repost in your own thread on the LS1 forum.
Old May 22, 2009 | 05:44 PM
kkollwitz's Avatar
thanks!
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
