Question about Fabricated Valve Covers
i just recently bought a pair of Fab'd. Valve Covers for my LT1...i noticed that they dont have holes for breather or PCV..will this be ok? or should i make a hole?
The PCV valve goes into the side of the intake manifold. The connection on the passenger side valve cover is the air vent line, that flows clean air from the throttle body, into the valve cover, through the crankcase and lifter valley, and out through the PCV valve. You need the vent line or a breather, as noted in the post above. The stock valve cover has a small baffle under the hole for the vent line, to limit the amount of oil the get into the vent line, if the PCV valve can't handle the blowby, and it starts to flow backwards through the line to the throttle body.
Jul 4, 2005 05:00 PM
