I'm going to kill somebody
Old Jun 12, 2006 | 01:19 AM
Wckd94Z's Avatar
so i get some sea foam today to clean out my 94, all goes well when i let the intake soak up 1/3 (ONE-THIRD!!!!!) of a can before the engine dies, now I was tilting the can, then straightening it to give the motor just a little bit at a time. so yea engine dies, i let it sit 20 minutes come back to start and....
after a few cranks, THUNK!, ****ing thing hydrolocks over 6 ounces of seafoam. so I pull the plugs, and on the last one, the insulator cracks in my hand when I'm lifting it out of place (6.99 delco platinum ) so off to the 24 hr autozone and i get a new plug. come back crank the motor and it spits all kinda crap everywhere, then i reinstall plugs. Done? NO
i get on with changing my oil with some fresh mobil 1, forget to fill up the filter in my hurry so I pull the coil wire and crank it a few seconds to distribute the oil. Put coil wire back on and try to start....
NOTHING but a damn flashing security light on my dash So obviously something prompted VATS to shut my car down, I don't know why I didn't disable that thing when I tuned it. whatever I'm resetting the PCM right now, which I think will turn off VATS? otherwise I'll just hook up my laptop and disable that ****.
End of rant.
Old Jun 12, 2006 | 01:53 AM
Wckd94Z's Avatar
Re: WTF I'm going to kill somebody
ok so after doing some research my new problem could be that my key is bad? what a terrible and random point in time to go bad... oh well i know a guy who can make me a new one for 35 bucks tomorrow
Old Jun 12, 2006 | 05:18 AM
Guest47904's Avatar
Guest
Eventually even a new key won't make contact with the worn out contacts in the switch. You're better off just bypassing the function with a resistor of the same value as the key pellet.
Old Jun 12, 2006 | 09:09 AM
multicar's Avatar
Yeah, those contacts in the ignition switch are so particular that all it takes it someone to try and put in the wrong key or the right key upside down and they get bent outta shape. Somebody said you could bend them back with a dental tool, most I've seen will just bypass it for a permanent fix.
Doug
Old Jun 12, 2006 | 01:55 PM
Wckd94Z's Avatar
Re: I'm going to kill somebody
thanks a lot guys, yea i did some research late last night and that's pretty much what i was reading. the resistance in my key is about 2467 ohms, so down to radioshack I go. oh yea thanks shoebox i saw the schematics for it on your page as well
Old Jun 12, 2006 | 02:07 PM
DrewHMS97SS's Avatar
just note that bypassing vats makes your car much easier to steal
Old Jun 13, 2006 | 10:07 AM
multicar's Avatar
True, but if you put a tiny(miniature) switch in series with the resister and then hide it.....then even the right or jimmied key won't start it.
Doug
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
jwade88
Jun 14, 2015 09:38 PM
Hobbyguy
May 26, 2015 02:15 PM
beltrunner
May 17, 2015 10:18 PM
TEG99SS
Apr 11, 2015 10:08 PM
