Quad Driver Failure
The Quad Driver is used to activate high current loads like solenoids. Getting a Quad Driver code - e.g. DTC 26 - does not necessarily mean the "driver" module is bad, it could mean the load that it is driving it faulty. Are you replacing the ECM because you are getting a "quad driver" code? Do you have a specific code?
I changed my PROM when I did my heads/cam, but my QDM failure code stayed in the computer. It didn't go away until I changed the main ECM.
Don't the Quad Drivers control the injectors on a '93?
Frank
Frank
Injectors could be!!!
Turn your ignition on (engine off), and with a voltmeter poke the terminals on each of the injector harnesses. Pink Wire is 12V, and the other wire (forget color) is the ground.
So poke the harness slot for the pink wire (12V power) and the harness slot for the ground wire. If you get a power reading (12V), then your injectors stay open, which will cause misfires, and lousy fuel mileague.
Let us know, and give us some feedback
I am not saying your injectors themselves are bad, I am suggesting that if that error codes is related to the injector drivers a good way to test would be that.
Follow me.
With the ignition, the ECM is suppose to supply 12 volts of power to each injectors harness (pink wire).
Now keep in mind that an injector is opened when both power and ground is given to it. This means the ECM fires each bank of injectors by grounding the ground wire. (blue or green).
So the test simply suggested to probe the pink wire slot on the harness (power) and probe for ground by probing on the blue wire (ground). If the voltmeter reads voltage, this means that the blue (ground wire) is grounded, therefore your injectors are always open.
Just a suggestion.
Follow me.
Just a suggestion.
squarehead
Jan 15, 2015 07:02 PM
