Q about guideplate sqeal?
Old May 27, 2006 | 07:02 PM
firebirdStud's Avatar
Exclamation Q about guideplate sqeal?
Alright. The new motor is in. This time I went Comp pro mags and comp guidplates and pushrods. My previous setup didn't have that, they were Self Aligning rockers. Anyway, I get kind of a high pitch squeal, very faint, almost like a belt squeal, but it sounds like its coming from under the valve cover and NOT the belt/tensioner/power steering pump. So, I was curious if the harmonics of the pushrod rubbing on guideplates would cause this slight noise I am hearing? The motor has about 170 miles on it now, so it has been running a bit. But today its hot, like 94 degrees in the twin cities, and I noticed that high pitch squeal. Anyone able to help me out? Ive never heard it before, it is connected with engine RPM, not vehicle speed that I am aware of.
Thanks!
Cody
(The new CSR water pump is keeping that motor cool too, hasn't gone over 175 degrees all day in the city or freeway. Gotta love new mods!)
Old May 27, 2006 | 11:19 PM
Z-RATED94's Avatar
Re: Q about guideplate sqeal?
I don't believe those guideplates are the ones you should be using. They don't quite line the pushrods up as well as the ones from GMMP or the Isky adjustables.
Old May 28, 2006 | 03:47 PM
yeah I already know that now. I will be getting the isky ones and making a weekend of it to swap them. I wish I would have known that BEFORE the damn motor install though. Oh well. The squeek seems to be getting louder. I just put a new belt on, could that still squeek??
Old May 29, 2006 | 01:08 AM
you know, I am starting to think that new belt must have gotten some coolant on it maybe. It comes and goes as it pleases...
Old May 29, 2006 | 05:25 AM
Dave89IROC's Avatar
start it with the belt off, if the noise is gone, you know its the belt
and there have been LOTS of threads on guideplates..................
Old May 29, 2006 | 09:43 AM
yeah i know, too many. It would take days just to figure out if guideplates do infact squeal, or if I should look elsewhere for this squeal.
Old May 29, 2006 | 10:38 AM
Z-RATED94's Avatar
Even if it's not the guideplates making the noise you might want to change them out anyways. That's a nice combination of parts you have there and I'm sure you want it set up as close to perfect as possible. And good luck on your dyno day.
Old May 29, 2006 | 07:53 PM
Yeah, I should get those isky ones comin in the mail anyways. And thanks for the dyno wish... Im pumped as hell! I can't wait to see what she throws down. Should I take off the belt while they dyno it so the motor isn't turning stupid stuff it doesn't need to be turning??
Old May 29, 2006 | 08:22 PM
roguedriver's Avatar
So whats better, guide plates with non-self aligning rockers or self-aligners without guide plates?
Ken R.
Old May 29, 2006 | 09:21 PM
Josh'95Z28conv's Avatar
Ken R.
NSA with guideplates.
Those iskys are a sob to set up as well. I wouldnt run them unless you have too. How did the roller tips of your RRs line up on the valves?
wytblur
Oct 29, 2003 08:01 AM
onebadponcho
Oct 20, 2003 01:44 AM
MattysTA
Oct 5, 2003 08:53 AM
94formulabz
Aug 27, 2003 03:43 AM
94formulabz
Aug 15, 2003 08:50 PM
