Putting a single plane on lt1 got some ?s
Old Jan 6, 2010 | 01:07 PM
stockssn2o's Avatar
I have a 388 lt1 with afr 227's on it i'm planning on putting a single plan efi on it with a 4150 nitrous plate and a nitrous works elbow to use the stock style throttle body
will a super victor efi clear a stock ss hood with this setup? i was also looking at the victor e intake because it has a shorter plenum. The nitrous outlet elbow is the shortest one i've found. I know there's people out there with a super victor on lt1s so feedback would be much appreciated
Old Jan 7, 2010 | 07:55 PM
stockssn2o's Avatar
i did alot of searching on this and found alot of info but still not what i need to know... i guess if nobody gives me some input i'll just order some stuff and hope it fits
Old Jan 8, 2010 | 10:19 AM
axehead's Avatar
some one help the guy out
Old Jan 8, 2010 | 03:59 PM
T/A KID's Avatar
Look here first, and look on LS1tech.com too a lot of good info
https://www.camaroz28.com/forums/sho...d.php?t=612745
Basically fix the bolt angle problem, setup an Elbow to use a LS1 or LT1 TB, use the fuel rails with the kit and setup your fuel system with a AFPR.
Just got done building my own conversion for less than $400, when I didn't know any better back in the day I paid $1600.
Fastfatboy has a Supervic with elbow and it fits under a stock style hood, should work with your SS hood no problem. Victor E is about 1inch shorter.
Old Jan 8, 2010 | 05:48 PM
stockssn2o's Avatar
thanks alot man
i'm gonna get the super victor and build an elbow ... with a crossplate under it...
i work at a machine shop so i'm sure we can make it work
btw i looked at your photobucket your car is sick... you got any pictures of your new intake setup
Old Jan 8, 2010 | 08:19 PM
T/A KID's Avatar
Thanks, I have worked on it for awhile. No pics of the super vic I need to take some though, check back soon and I probably have some up.
Old Jan 8, 2010 | 09:27 PM
stockssn2o's Avatar
will do do you have the part number for the washers you used
Old Jan 9, 2010 | 02:10 PM
T/A KID's Avatar
http://www.cableartinc.com/fittings/10/pdf/hardware.pdf
Part number 40HAW1230
Pretty expensive I bought 8 of them and there around $3 a peice, but there stainless and you don't have to machine anything.
Old Jan 9, 2010 | 03:03 PM
stockssn2o's Avatar
i think i'll just machine the intake i do work at a machine shop after all and we've done it before about a half hour in the bridgeport and its good to go
DirtyDaveW
Dec 1, 2016 05:37 PM
Queens94z28
Dec 20, 2014 09:11 PM
bossco
Nov 29, 2014 10:18 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Elcojoe
Nov 17, 2014 10:27 PM
