pushrods?
Old Nov 7, 2006 | 08:15 AM
gpss97's Avatar
pushrods?
will this size pushrod work for a 97 lt1? the heads aren't milled or nothing like that..just 306 cam,roller rockers,etc. 7.218??? thanks
mike
Old Nov 7, 2006 | 09:33 AM
1racerdude's Avatar
mike
Ya have to measure. Guessing is NOT good.
Old Nov 7, 2006 | 10:04 AM
jsetzer's Avatar
Stock size "should" work with the 306, but you really should get a checker and test it.
Had a setup with a 306 and the guildplates did not wear with stock pushrods. Switched to an 847 and they started wearing, go figure.
Old Nov 7, 2006 | 10:06 AM
sssalah's Avatar
Most probably they'll be good. Check the valve tip contact pattern to confirm.
Old Nov 7, 2006 | 10:14 AM
gpss97's Avatar
yeah i was just curious..cause the 7.2 work, but my friend had some hardened pushrods that are that size and he said if they fit that i could have them..so i'll just get ahold of some and measure and what not. thanks
mike
Old Nov 7, 2006 | 11:04 AM
2000GTP's Avatar
They "should" work, but it is always a good idea to check them. The length checker tools are not expensive at all.
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
