What all needs to be done to the block to install a 383 stroker assy?
Old Nov 6, 2006 | 10:41 PM
remaxracer45's Avatar
Have my motor down thinking of going with a 383 stroker assy, crank rods and pistons? What all must be done to the block to install this setup? Thanks
Old Nov 7, 2006 | 09:47 AM
Remove all expansion plugs and galley plugs. Hot tank/degrease block and clean out the water passages and oil passages. Ultrasonic check the cylinder wall thickness. Magnaflux for cracks. Check deck for squareness and finish. 4-bolt main conversion for "power adder" application - optional. Bore/hone cylinders to 4.030" using a torque plate. Clearance oil pan rails and bottom of the cyinder bores for the crank counterweights and rods. Align bore the mains.
Old Nov 7, 2006 | 12:39 PM
Sinister95Z's Avatar
Informative and Impressive.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
