pushrod and lifter question
Old Jun 20, 2004 | 12:30 AM
96birdlt1's Avatar
Are the stock pushrods and lifters good enough for a CC305, ported heads, and 1.6 roller rockers?
Or, do I need to go with another set?
Any help would be awesome.
Joe
Old Jun 20, 2004 | 02:35 AM
rskrause's Avatar
Moderator
Re: pushrod and lifter question
Joe
Generally speaking, yes.
Rich Krause
Old Jun 20, 2004 | 03:10 AM
5.0THIS's Avatar
Pushrods are the weakest link in a pushrod motor, and a set of better pushrods would be cheap insurance, but that's just me
Old Jun 20, 2004 | 11:25 PM
96birdlt1's Avatar
Re: Re: pushrod and lifter question
Rich Krause
Yes, to the first or second question?
Joe
Old Jun 20, 2004 | 11:30 PM
cmillard's Avatar
Someone correct me if I'm wrong please (as always.)
stock LT1 pushrods were hardened from 1993 -1995, so if you've got a 1996 you might want to check and see if yours are hardened. If they are, I'd leave them alone mine have been fine for 80K+ miles and 360 rwhp no problem.
Hope this helps, money saved is money better spent on other mods,
-Christian
Old Jun 20, 2004 | 11:36 PM
96birdlt1's Avatar
that's what I am wondering about. I still have a few other things to buy for my head, cam and LT header swap that I am in the middle of. If I can reuse any parts safely then I would rather right now. Pushrods are pretty easy to change later on, unless it is needed now.
Joe
Old Jun 20, 2004 | 11:44 PM
5.0THIS's Avatar
Joe
I personally think even if you have the factory hardened pushrods that it might not be a bad idea to at least get a new set of hardened pushrods, especially if your car has a lot of miles. If your 96 does not have hardened pushrods, then you'd be cutting corners if you didnt get new ones.
Old Jun 20, 2004 | 11:51 PM
96birdlt1's Avatar
I guess that it may be too much to risk, so I will change them.
What size do I need and where to get them at a good price?
Joe
Old Jun 20, 2004 | 11:57 PM
Spinner's Avatar
Factory rods are 7.2". Combination motorsports (cmotorsports.com) sells a nice set (EX) for around $35 I believe. I've not had an issue with them, and they're high quality
Old Jun 20, 2004 | 11:58 PM
96birdlt1's Avatar
thanks for the information, I will check them out.
Joe
Old Jun 21, 2004 | 12:17 AM
med_reject's Avatar
ported heads might need slightly different length. See if u can get a pushrod length checker to determine the optimum length, and then buy the pushrods.
Old Jun 21, 2004 | 12:21 AM
96birdlt1's Avatar
Will do. I am thankful for any tips you guys throw my way. I am wanting to do this without messing anything up.
Joe
Old Jun 21, 2004 | 12:23 AM
96birdlt1's Avatar
Oh, I just thought about all the responses being about the pushrods. What about the lifters, are they alright to reuse with the CC305 cam?
Joe
Old Jun 21, 2004 | 01:35 AM
5.0THIS's Avatar
Joe
well, many people reuse them and have no problems. I'd say how many miles is on them may determine how well they'll perform under more load, and against stiffer valvesprings
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
