Pushrod length w/solid roller..
Old Jul 15, 2007 | 12:54 AM
way2evl's Avatar
Decided to change my setup to a solid roller.. I have some brand new comp hi tech 7.150 pushrods. I went with those because my block is zero decked and my heads have been cleaned up and running a .039 head gasket.. Does anyone think Ill need a different length for the solid roller motor?
Old Jul 15, 2007 | 01:42 AM
turnin20s's Avatar
You'll have to get a measuring pushrod to be 100% sure, they are only $25 or so from summit. Every motor is different so the best way is to buy the length checker
Old Jul 15, 2007 | 05:00 AM
Projectz28's Avatar
Moderator
only way to be sure is to measure them when you get the motor assembled. But 7.15 is probably way too short... depends on the lifters. Most SR lifters are shorter than HR lifters. My SR ended up with 7.850".
Old Jul 15, 2007 | 05:25 AM
SS RRR's Avatar
What lifter are you going to use? I went with Isky ReZone lifters which are significantly taller than stock and went to a 6.155 PR.
Old Jul 15, 2007 | 09:12 AM
Projectz28's Avatar
Moderator
I used comp endurex lifters in mine and they are shorter than a stock HR lifter. Most solid lifters are shorter. Just depends on what you go with.
Old Jul 15, 2007 | 10:21 AM
rskrause's Avatar
Moderator
The chance of them being the right length is just about zero.
Rich
Old Jul 15, 2007 | 11:47 AM
way2evl's Avatar
Morel SR lifters
Old Jul 15, 2007 | 01:32 PM
SS RRR's Avatar
Morel SR lifters
Whatever brand you decide to go with you need to measure with a PR length checker.
Old Jul 15, 2007 | 01:39 PM
Projectz28's Avatar
Moderator
ditto
Old Jul 16, 2007 | 01:26 PM
SStrokerAce's Avatar
Good Advice for a change!
Old Jul 28, 2007 | 04:51 PM
High-tide's Avatar
Did you have to or would you have to remove your heads to replace any of these lifters? What comp part number lifter did you get?
Old Jul 28, 2007 | 05:18 PM
Projectz28's Avatar
Moderator
honestly I built it from the bottom up and ht elifters were already in when the heads went on. So I dont know for sure but I think they would fit just fine. I bought the lifters used here on the board. (barely used... run on a dyno and then removed) They were 888-16's I believe.
Old Jul 28, 2007 | 05:26 PM
High-tide's Avatar
I checked the Comp Cams web page and 888-16 appear to be the same .300 taller as the 871-16 that we can not install without removing the heads.
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
