well......
Old Jul 27, 2007 | 11:44 PM
green96ta's Avatar
well......
after that good time i had at the track my ses light came on on the way home from work. ahh oh well it happens. prob just a sensor...it didnt seem to be running any different. well i was really wondering about roller rockers... do you really gain as much as advertised? what ratio? thanks for all the help and support!
Old Jul 28, 2007 | 07:27 AM
95zsean's Avatar
Yes with you Mods you should.Just remember that you have to change the valve springs if you use 1.6 RR.
Old Jul 28, 2007 | 08:05 AM
wrd1972's Avatar
Very much worth it to get some 1.6 rollers, yes the stock springs must be replaced with something better or you will coil bind.
Old Jul 28, 2007 | 09:31 AM
green96ta's Avatar
hmm
wrd- what valve springs did you use?
Old Jul 28, 2007 | 09:34 AM
Dave1980's Avatar
Being you have not put a cam in YET , I would think LT4 springs would work fine. You could also just save and do a cam and springs swap. (matched of course)
Old Jul 28, 2007 | 09:41 AM
green96ta's Avatar
hmm
well its gonna be at least 6 months to a year before i can do a cam. if i do a small cam, like a lil bigger than a hot cam will i still be able to use the rockers?
Old Jul 28, 2007 | 09:53 AM
Z-RATED94's Avatar
Some full roller CC magnums would be nice. Do a search. And if you go larger than the Hotcam, you will be replacing springs again.
Old Jul 28, 2007 | 08:45 PM
green96ta's Avatar
egr
well that code was the egr valve...cleared it and it hasnt came back one...so keep your fingers crossed!
Bluovlh8er
Jan 16, 2008 07:52 AM
Darth Xed
38
Nov 5, 2006 01:54 PM
