Pushrod length change when changing cam only???
Old Mar 19, 2008 | 08:08 AM
always faster's Avatar
Well i was looking at the AI cam package(Ai 226 / 234 - .540/.575 - 110 LSA ) and i like the fact that everything is included...im lazy
I was just wondering if the pushrod length change if you only change the cam and doesnt touch the head or rocker ratio(already 1.6)?
I think that right now im running some 7.20 inch long one.
Wanna now because i need to specify the length when ordering.
Old Mar 19, 2008 | 09:06 AM
ss.slp.ls1's Avatar
7.2 is stock and it shouldn't change with the cam. You can get away with using the stockers, but most run chrome moly pushrods for peace of mind.
Btw...why cam only? Throwing in a set of 1.6rr and some springs will compliment the cam nicely.
Old Mar 19, 2008 | 09:23 AM
user 647483's Avatar
With the heads staying mounted to the block (thus no milling or head gasket change) pushrod length should remain stock.
Old Mar 19, 2008 | 09:29 AM
JooneJune's Avatar
i thought the length was 7.250? 7.2 works though.
Old Mar 19, 2008 | 09:48 AM
2000GTP's Avatar
Yes, 7.20" is the stock length.
Old Mar 20, 2008 | 10:18 AM
I got an lt4(with les than 1500miles on it) so im already running 1.6 rr.Just wanted to be sure to ask for the good pushrod length.
The kit from AI come with those parts:
Any of our Ai Billet steel cam grinds listed below
PAC Racing 1218 Ovate-wire Beehive Springs
CompCams ChromeMoly Steel Retainers
CompCams 10-Deg Steel Locks/Keepers
CompCams Hardened Steel Spring Locators
OEM Quality Steel Jacketed Viton Seals
K-Line Valve Seal Installation Driver
ARP 7/16" Pro Series Rocker Studs
CC1305 Pro-Magnum Rocker Arms - 1.6 Ratio
Ai Hardened & Black Oxided Steel Guideplates
Ai 4130 One Piece ChromeMoly Hardened Pushrods 5/16" x 7.XX" .080" Wall
Old Mar 20, 2008 | 01:16 PM
gatorhead's Avatar
As Ron or Phil will most likely tell you they will not guarantee it will work, but it should. The proper way would be to get your package and install it, use an adjustable length pushrod and see what you need. Get back with them and order your pushrods
Old Mar 20, 2008 | 01:22 PM
speed_demon24's Avatar
+1, call them up and talk to them. And just a heads up, S/A rockers won't work with beehives on stock LT1 valves so you will need new NSA rockers.
Old Mar 20, 2008 | 01:56 PM
marshall93z's Avatar
IF the base circle is the same.
Old Mar 20, 2008 | 02:18 PM
rskrause's Avatar
Moderator
As a purist, I should say you must measure, and if you are going to get new PR's anyway, then you definitely should measure before ordering. But why not just keep your current R's and see if the length is still ok, then just re-use them if it is?
Rich
Old Mar 20, 2008 | 03:14 PM
Rich
I cant reuse my rockers even if they are 1.6 because they are SA.
Old Mar 20, 2008 | 05:56 PM
1989TransAm's Avatar
To find the correct length pushrods you have to have the correct geometry. Then to open Pandora's box what is the correct valve train geometry?
You can have 10 people and get 10 different answers. Not even all the cam companies agree on how to get the right geometry.
Old Mar 20, 2008 | 06:26 PM
You're right, I made the assumption that he was retaining a stock base circle.
HectorM52
Jul 30, 2017 11:46 AM
armedtrigger
Feb 24, 2015 08:30 PM
chuyz28
Feb 19, 2015 12:50 AM
birdblack
Dec 30, 2014 06:59 PM
