are pullys messing up my car???????
Old Oct 25, 2006 | 10:46 PM
25th trans am SD's Avatar
Question are pullys messing up my car???????
I have just insalled the set of march pullys on my 94 trans am..and for some reason when I have it on first gear (automatic) and give it a little gass my car is just reving for about 3 sec then it pulls and also when i floored it on drive the cars rpm;s went to 6500 and didnt shift....as when i had my stock pullys they would have a very fast reaspond and not have one problem with it reving and going nowhere
Old Oct 25, 2006 | 10:53 PM
MeanGreen97Z's Avatar
Have you tried putting the stock pulleys back on and seeing how the car runs? Sounds like a transmission issue to me more than anything. Hit a transmission line while you were installing those pulleys perhaps?
Old Oct 25, 2006 | 11:08 PM
where is the transmission line???????
Old Oct 25, 2006 | 11:19 PM
95z28_m6's Avatar
First I would check the level of fluid in your tranny. If it is low then check 4 leaks coming from trans lines, seals, or gaskets on your trans. (just sounds alot like what my th350 does when the fluid gets low. Bad pan gasket)
Old Oct 25, 2006 | 11:34 PM
[QUOTE=95z28_m6;4184550]First I would check the level of fluid in your tranny. If it is low then check 4 leaks coming from trans lines, seals, or gaskets on your trans. (just sounds alot like what my th350 does when the fluid gets low. Bad pan
i know that the tranny is good.............. as soon as they where istalled them i was trying to take off on 1st racing a nasty crx and it just reved then gets a hold a while after ............o ya and i smoked him
Old Oct 25, 2006 | 11:39 PM
95z28_m6's Avatar
Well I would still just check the fluid level. I cant hurt anything.
Old Oct 25, 2006 | 11:41 PM
thanks for the help
PCLZ28
Dec 24, 2015 05:19 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
