Pulling heads
Old Jan 7, 2006 | 03:59 PM
ZMaster's Avatar
Pulling heads
All right guys, I'm getting ready to pull the heads off to send them to LE. I was wondering, it's going to be about 3 weeks until i get them back. Moreover, I don't know how long it'll take me to get off my lazy *** and get them back on. My question is, is there anything special i should do since the motor is going to sit with no heads for a month. Should I just put some rags over it and close the hood? Or is there something more in-depth I should do. Thanks guys.
Ian
Old Jan 7, 2006 | 04:16 PM
Cmr0z28's Avatar
Re: Pulling heads
Don't use any rags that will leave lint in the engine. And cover it with garbage bags if you can.
Old Jan 7, 2006 | 04:17 PM
FastZinTennessee's Avatar
Re: Pulling heads
I've always thought that saran wrap on the sealing surfaces would work well, maybe put some motor oil on the surface and then put the saran wrap over it. If you are worried about it blowing off (maybe if the car will be parked outside) put some magnets on corners to hold the plastic on.
Old Jan 8, 2006 | 08:21 AM
pearlpurple's Avatar
Re: Pulling heads
is it outside/inside??
Mine was inside when I had my heads off I took a rag (clean) soaked in oil wiped down exposed surfaces and just laid a bunch of rags across as a dust shield and closed the hood.
I wasn't worried about lint.
Before going back in to re assemble I again wiped down and used my shop vacuum to pick up the rest of dirt and any "lint"
I like the magent idea if you are outside
Old Jan 8, 2006 | 03:13 PM
ZMaster's Avatar
Re: Pulling heads
I appreciate the ideas and advice guys. The plastic wrap seems appealing, and it's going to be stored inside the garage. Thanks.
Ian
Chris Anderson
Jan 27, 2015 08:30 AM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
CobraEatr
Jul 29, 2002 11:46 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
