Can i use this injectors to my LT1 97
i iam just installing my LE2 just wondering if i can use this injectors
http://cgi.ebay.com/ebaymotors/Chevy...spagenameZWDVW
im asking because i never heard about multech injectors,
thx for the info
thx for the info
Re: Can i use this injectors to my LT1 97
They are described as "low impedance" injectors. To my knowledge, the stock PCM will not drive low impedance injectors, unless you get an external "black box" driver to add onto your system. Its an easy enough item to add, but its going to run up the cost without helping you in any way.
The injectors are also described as "externally cleaned"... which means they wiped the grease off the outside and checked them with an ohm meter. They could be filthy or plugged internally, so buying them, since they are sold "as is" is a huge crap shoot.
I personally would not even consider them.
Might want to add some info.... what year is your car? A "signature" helps people answer your questions.
Jul 4, 2005 05:00 PM
