Brake Job
Old Apr 20, 2003 | 10:17 PM
zuluman13's Avatar
Brake Job
How much does a brake job cost with the full service and resurfacing the rotors I just need the front brakes done im looking to do it as inexpensive as possible without being junk thanx.
Old Apr 20, 2003 | 10:26 PM
LPEdave's Avatar
Pads from AutoZone somewhere less than $100 for the fronts, anti-squeal goo $1, a pint of fluid less than $10, resurfacing rotors maybe $25 each.
Dave
Old Apr 20, 2003 | 10:35 PM
eyeoutthere's Avatar
Just buy new rotors, don’t have them resurfaced. Change the part yourself with basic parts from AutoZone, Napa, or the like. I have found the Advanced Auto Parts has a 1-year warrantee on their rotors compared to the 90day warrantee of AutoZone, and your rotors WILL warp within a year so you’ll be able to get new ones. Should only cost you $90 or so for new rotors and pads.
If you have it done for you, they are doing to rape you; 200-$300 most likely.
Doing it your self is real easy. All you have to remove is the tire and caliper (the caliper is held on by only 2 bolts). You’ll probably have to buy an Allen head socket for the calipers (the guy at the parts store should know what you need). Other than that all you need is a C-clamp to depress the caliper and ratchet.
There is a pretty simply break job write-up floating around here somewhere. You should probably buy a Haynes manual though (or something similar), they come in real handy.
Old Apr 21, 2003 | 01:20 AM
chasmanz28's Avatar
yeah man do it yrself, same some money, and do it right in the process
30th Anniv Z28
Aug 1, 2015 10:39 AM
hcarrickz3
Jul 21, 2015 08:46 AM
whitehooptie
Jul 12, 2015 06:10 PM
