pulling engine problems
Old Aug 27, 2007 | 11:55 PM
Explodinggopher's Avatar
Got everything ready to go cherry picker is holding the engine up and the motor mounts are unbolted, can wiggle the motor around freely too. I unbolted the T56 from the block but can't get it to separate from the engine, it seperates about an inch or so but no further. Do i have to unbolt the slave cylinder and/or get the clutch fork off the throwout bearing for it to slide off? I'm missing something here and i don't want to break anything. I have a jack under the tranny to hold it up too, its just not letting the block slide forward off the input shaft. Thanks for the help.
Also, i have one grade8 bolt in the water pump hole and one in the back of the head holding this up, is this ok with the soft aluminum head as long as its threaded in the good? i didn't see any block holes to bolt to on the back.
Old Aug 28, 2007 | 05:28 AM
1BigBird3's Avatar
Originally Posted by Explodinggopher
...Do i have to unbolt the slave cylinder and/or get the clutch fork off the throwout bearing for it to slide off?....
Yesssssir.
Grade 8 is the minimum bolt grade I would use when lifting the motor. Be sure you can thread the bolts in atleast half way to ensure a safe lift.
Goodluck!
-Ruben F.
Old Aug 28, 2007 | 07:23 AM
cehan's Avatar
Yeah, you have to remove the slave and pull the clutch fork away from the throwout bearing. There's two small spring clips on the fork that hold it in position on the throwout bearing.
Old Aug 28, 2007 | 03:16 PM
chief455's Avatar
I was looking at pulling the motor - even just the oil pan from my car.
Wouldn't it be easier to drop the k-member?
Old Aug 28, 2007 | 03:18 PM
It is a subject of many debates. Out the top or out the bottom. Lots of threads you can read about it.
Old Aug 28, 2007 | 03:23 PM
seawolf06's Avatar
Yeah, you have to get that fork off of the TO bearing to get the tranny to seperate. I hope you have a happy hooker or something like that.
If you go out the bottom, it's pretty easy and much easier with the use of a lift. You have to take some brake lines loose and let the A/C out (not sure if you have to do that from the top), but you don't have to take the hood off. Rob's right, there are opinions that go either way. I like it out the bottom, myself.
Old Aug 28, 2007 | 10:51 PM
chief455's Avatar
I see.
My mechanic has a lift so I guess......
DirtyDaveW
Dec 1, 2016 05:37 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
