Pulley Question
Old Dec 5, 2005 | 05:22 PM
fattyz28's Avatar
Pulley Question
Has anyone ever noticed any extra vibration from a set of march pulleys? My car has been shaking like it has a cam in it. I changed the plugs and wires at the same time I installed the pulleys, so surely it isn't a plug fouling out already. My rpm's aren't jumping just the car feels like it has a lope.
Any help would be nice.
Thanks,
fattyz28
Old Dec 5, 2005 | 09:28 PM
OBE1 95Z28's Avatar
Re: Pulley Question
The pulleys are neutral balanced so they shouldn't cause a vibration. More likely you don't have a plug wire fully seated and you have arcing to the head/block. Inspect for arcing (sparking) around the park plug wires in the dark with the engine running.
Old Dec 6, 2005 | 07:48 AM
Re: Pulley Question
Is the crank pulley a "sandwich" type? Did you reinstall the damper?
Old Dec 6, 2005 | 06:11 PM
fattyz28's Avatar
Re: Pulley Question
It is a sandwich pulley. The triangle that is on the original was pointing in the same direction for installation and removal.
I didn't think about the wire arcing. I will check that out.
Thank you both for the ideas, anymore feedback would be great.
fattyz28
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
jasonduaine
Mar 7, 2015 09:44 AM
cyteone
Feb 7, 2015 06:04 PM
